book collections email follower instructable user
Step 8: How the Code Works: Scanning the Matrix
For scanning the matrix, I manipulate the data lines directly, as this is more efficient than using the AdaFruit library to paint pixels. To disable the AdaFruit library, I shut off interrupts prior to beginning a scan. Since the AdaFruit library works by using interrupts, this allows me to take control of the matrix temporarily.
The matrix has six shift registers, corresponding to the R, G and B colors of an entire rows of pixels in the upper and lower halves of the matrix. There is also a latch control line (LAT), which copies the values from the shift register to the LED drivers. Four address lines (A, B, C and D) select which rows of the upper and lower half are active and an OE (output enable) turns the LED drivers on and off.
In normal operation, the latch keeps a row illuminated with previous values while a new replacement row is shifted into the shift registers. Once the entire row has been loaded, the new values are latched and the process repeats for the next row. This manner of updating requires an entire row to be written, even if only one pixel needs to be written.
For scanning, I chose to take advantage of the shift register, but not the latching functionality. I set the latch control line (LAT) to HIGH, making it so the contents of the shift register are loaded into the LED drivers immediately on each CLK pulse. Once I illuminated the first pixel, each pulse on the clock line (CLK) causes the lit pixel to get pushed down the row to the next pixel. In so doing, I can push the illuminated pixel down the row to scan the entire row.
For each position in the row, I use the OE (output enable) line to strobe the pixel on and off while taking the readings from the light sensor. Once I have enough readings to make a determination of whether that pixel is visible or not, I write a color to the AdaFruit library's framebuffer (while scanning, I can still write pixel values to the library's framebuffer, even though the library is temporarily suspended).
After all the rows have been scanned. I re-enable interrupts, which causes the AdaFruit library to refresh the matrix with the data in the buffer until I am ready for the next scan.
OscarC242 months ago
very nice approach, at first i think you where using the fact that led can also be used as very poor photocell and scan each led voltage against the shadow of an object placed in front of it. iam sure it can be done to.
