book collections email follower instructable user
Picture of Ultra Realistic Surfing Simulator
Do you feel a sudden urge of going surfing, but there is no large body of water nearby? Are you scared of deep and turbulent waters? Or are you just to lazy to go outside? Then the Ultra Realistic Surfing Simulator is the perfect solution for you! It allows for a close to reality surfing experience from any place imaginable. As a two part system, motion is sensed by a board and translated into wave motions of an ocean diorama.
Project by:
Lena Strobel, Gabriel Rihaczek, Guillaume Caussarieu
The project was conducted as part of the Computational Design and Digital fabrication seminar in the ITECH masters program.
Step 1: Materials
To build a Ultra Realistic Surfing Simulator, you will need the following supplies :
Electronics:
  • 2x Arduino Board (Arduino Uno)
  • 2x Batteries 9V
  • 1x Servomotor, e.g. ServoMotox Reely Standard-Servo S-0090 (88/98N.cm)
  • 1x 3 axis digital acceleration sensor module - MMA8452
  • 2x NRF24L01 Transceiver Module
  • 6/7.5V Power Supply, e.g. Voltcraft USPS-1000
  • 2x 5.1kΩ resistor
  • 1x Breadboard
  • Jumper wires
Hardware:
  • 2x Plexiglas sheets 250x500x3mm, e.g. Evonik
  • 1x Plexiglas sheets 250x500x2mm, e.g. Evonik
  • 20mm Plywood board (91*21cm + 2x 91*11cm)
  • 4x M3x15mm Bolts
  • 8x M3 Nuts
  • 1x Ø8x20mm Aluminium sleeve (1mm thick)
  • 1x M6x50mm Bolt + 2xM6 Nuts
  • Ø3x50mm threaded rod
  • 2x Ø8/4mm washers
  • Ø5x50mm wood screws
  • Blue Water colorant
  • 1l of transparent baby oil
  • 1x Tube Acrifix 1R 0192 (or other clear and waterproof acrylic glue)
  • Transparent silicon
Tools:
  • Plyers, Screwdriver, Power Drill, Laser Cutter, Wood band saw or CNC mill, 60ml syringe
Really nice job putting this all together :)
