book collections email follower instructable user
There are times where we face power outages when we have some important work to carry out online. Your Home WiFi does not run when there is no power in your house. To fix that issue we will use the power of the sun to power our WiFi.
List of necessary items:
1. Solar Energy Kit
2. MT3608 Boost Converter
3. Copper Perf Board (Optional)
4. Wires
5. Nuts and Bolts
6. Battery Connectors
7. Heat Shrink Tube
8. Switch
9. Female Power Connector
Step 1: Disassembly of the Portable Solar Energy Kit
Picture of Disassembly of the Portable Solar Energy Kit
I will use this portable solar power system for this project, but it does not provide a 12 volt output, so we will need to boost it to the required voltage of the WiFi router. I will remove the four screws holding the cover in place. The battery will be disconnected from the charging circuit and the circuit will be removed as well after taking out the two screws holding it in place.
