book collections email follower instructable user
Picture of Setting up basic x10 for newbies
Turning on and off your lights with a non-ir remote is really easier and cheaper then it looks and sounds. This how-to shows how to configure an x10 remote for 2 lights. Also shows using a label-making machine to label the remote.
Step 1: What is x10, and what is this project about?
x10 is the next step towards home automation. Can you imagine opening your garage with a remote when you come home from work, and also turning on your lights wiht a different remote? Sounds like it would cost alot of money and technical understanding. But the truth is, and the x10 wiz people don't want' you to know this, it's easy to do and pretty cheap. I picked up this remote and 1 reciver for $20 at Radioshark. I got the other reciver later. they can be REALLY cheap on ebay.
shepnstein2 years ago
x10 modules leak a small amount of current by design. This had no negative impact in a world of incandescents, but will cause CFL and LED bulbs to flicker even when they are turned off. You can hack the modules so that they will work with these bulbs by cutting a diode on the circuit board. Here's a link http://www.laureanno.com/x10-mod3.html
To get a lamp module to work with LEDs and CFLs and low-power incandescent, you have to remove components associated with the local control feature.
If you are ok with doing mods to your appliance module, open it up and locate the 100K resistor (brown-black-yellow bands) and the 330K resistor (orange-orange-yellow bands). Chop both out of the unit. Or at least clip one lead of each.
The local control feature won't work, but LEDs and other low-power bulbs will work fine.
This will also reduce the quiescent power drain of the module.
The user manual here will show how to program the house and unit codes to the wall switch. https://www.x10.com/ss13a.html
yizi8 years ago
newestedhardy.com is a good website. I purchase many products on this website. And it’s no any customs problem.
bombmaker29 years ago
o wow i hav the same exact label maker, except for the label that says PAUL'S LABEL MAKER
geo13 years ago
I also have full source code for an x10 daemon program I wrote, which allows you to control your whole x10 system from a PC running Linux. Please let me know if anyone's interested, and I'll post the file in a new project
I'd like to see your X 10 code.
driggs geo13 years ago
Yes, please. It would be much appreciated...
rethomas197211 years ago
Take a look at www.x10.com. Each module shown above with the antenna can control up to 16 different functions and a 16 switch hand held remote and a 4 button key chain remote available, With the 16 numerical items there is also A to Z Alpha settings for a combined capability of 256 controllable functions using multiple Transceiver modules. You can even get a programmable TV remote with the X-10 controls on it. They also have a "Whole House" option which allows you to control things with your computer they can even control your house function by internet. X-10 also has a great line of remote cameras.
Fluorescent lamps can be turned on & off by using an "APPLIANCE MODULE" instead of "LAMP MODULE" but they cannot be dimmed .
I have pulled the appliance module apart & removed the AC plug & receptacle & "Hard wired" the module into the fixture. I have also done the same thing with ceiling fans. See Geo's Instructable
https://www.instructables.com/ex/i/6A1D1BCECA231028A849001143E7E506/
Chico13 years ago
Nice instructable! My only issue/disappointment with x10 is that it doesn't handle flourescent lightbulbs. So if the circuit you are controlling has some, plan on using incandescent bulbs instead. Otherwise, it will drive you NUTS!!!!
AlexPDL Chico11 years ago
X10 Can handle fluorescents... I think there are issues with dimming fluorescents though. Just make sure it's a fluorescent compatible x10 module. I use three X10 items with fluorescents... two wall switches and a lamp plug module. Never had a prob.
sunyi12 years ago
Nice instruction! Isn't The first word in step 7 should be "mounting"?
geo13 years ago
See also my project here, about modifying your x10 wall switches to add local dimming capability:
//Geo
