book collections email follower instructable user
First and Foremost: I followed another Instructable to build the Arc Reactor. As stated in the other instructable, it was about a 9 hr build. This particular build is more than 9 hours long, as I wanted the lights inside the ring to do more then just turn on/off. I started this project by designing and building a 10 channel L.E.D. chaser circuit to put into the Arc ring. If you want to view the Arc reactor and circuit in action, go here.
Equipment Used for this project:
craft glue gun, craft glue
X-Acto Knife set for cutting, trimming
Drill and drill bits (sizes: 7/64", 3/16:", 13/64", 3/8")
Soldering Iron, Dremel, routing bit for dremel
Electronic Parts List:
10x 5mm bright L.E.D's (clear-white)
3x 5mm bright L.E.D's (clear-blue)
1x 10mm bright L.E.D (clear-white)
14x 1K ohm (1/4 watt is fine) resistors, 3x 100 ohm (1/4 watt is fine) resistor,
1x 10k ohm trim pot
1 555 timer, 1x 4017 decade counter
2x 10uf(16V) capacitor
1x 4007 diode (for reverse polarity protection)
22 gauge bare copper wire (for windings)
18-20 gauge bare copper wire (for internal rings)
22-26 gauge ribbon cable wire for the 10 channel output of the 4017 chip to L.E.D.'s
perforated board to solder electronic parts together
RJ11 female telephone jack connectors, RJ11 male telco connectors with wires
1x SPST switch
1x 9V battery, 1 9V battery connector
Materials:
Craft Glue
homemade plastic mold (made from moisturizer lid-diameter 104mm), can of beans(diameter 65mm), wood base, screws to hold into place)
040"(1mm) thick PolyStyrene
Black tape
6x computer motherboard stand-off's, 3x motherboard screws (to hold the inner ring in place)
Optional Materials for Iron Man Costume:
4'x8' Durafoam to make a 'Iron' look for the Iron Man costume
2 rolls Duct tape
old back pack with straps
Industrial strength velco with double sided adhesive
Tear Drop template for steam vent cut-outs
Old pair of hockey gloves
2 under counter lights from a dollar store
6x 'AAA' batteries for the pulsar lights
optional Halloween color Velum paper(available on ebay) to put over the pulsar lights
shin pads, preferably back catchers shin pads
**PATIENCE** lol
Step 1: Designing and Testing the Chaser Circuit
Picture of Designing and Testing the Chaser Circuit
I took the circuit design and diagram from www.eleccircuit.com. I made a modification for the timing part of the circuit. I changed the values of the 2 resistors on either side of the 10K trim pot to 100 ohms because I wanted the 555 Timer to pulse as fast as possible to give the ring a glow affect when the pulse reaches it's maximum. To view the circuit in operation, go here. Click to view the circuit diagram.
I put the circuit together on a breadboard to make sure it worked properly. Then I left it all connected until the glue ring was ready for the L.E.D.'s. I put a picture of a finished circuit soldered to a perforated board and used the RJ11 female connectors and hot glued them to secure them to the board.
randya404 (author) 2 years ago
Thank you for commenting, I'm glad you enjoyed it!
Wow !! Really cool :)
Awesome :) loved it
Awesome!!! I will definitely make this :)
randya404 (author)  Anirudh Ralhan2 years ago
That's great! Let me know if you have any questions.
That is seriously one of the best arc reactors that I have seen. I am definitely going to try to make one for my son's Iron Man costume.
Thank you so much! Let me know if you have any questions.
