book collections email follower instructable user
Step 8: Making the Case - Adding the Components
The case I used is an old flashlight that I had lying around. The lens section was a perfect spot to add a small speaker. The case is a tight fit for all of the electronics but I wanted tpo make a pocket sized flzzle loop synth this time.
Steps:
1. First you need to design the layout of the pots and switches. This is an important part, especially if you are using a small case like I did in thsis build.
2. You'll also need to take into consideration how everything will fit inside the case. Wires, battery and the circuit board will need to be cramed inside so make sure you plan this out too.
3. Once you have planned out the build it's then time to start to add the components. Drill the holes in the case and attach all of the pots, switches and LED's needed for the build.
