book collections email follower instructable user
Picture of DIY Wireless Spy Camera With Two Android Phones or Tablets
This Instructable will show you how to make your own spy/security system from two Android phones or tablets and a few apps.
Step 1: Step 1: Supplies and Necessary Apps
Picture of Step 1: Supplies and Necessary Apps
For this you will need:
- Two Android phones or two Android tablets. (Or one of each)
- The IP Webcam app
- The VLC App
On one of the devices, download the IP Webcam app.
On the other device, download the VLC app.
IntanW22 months ago
Great DIY Will. I might try one as it has vast usage overall. I did however hack a phone while doing my own DIY - https://www.cocospy.com/blog/hack-phone-by-number.html - and the system was broken. I have studied phone security and still trying to improving on my own through my website, I hope you don't mind me sharing.
DrColg86 months ago
Any way to overcome using without a static IP address? I'd like to set up while away to check on the puppy, but fear my IP addressed would be recycled/changed by the time I need to log in
Will Ret (author)  DrColg86 months ago
For this specific way, I don't think there is. However, there are other apps out there that create a direct connection, but most of those are paid apps. I don't think that the IP address changes, But havent tessted it.
Hi, you can install VLC on to any computer on your local wifi ip and view it that way too. if you use local network, you'll have no costs for data.
tytower2 years ago
I'm wondering how this is being transfered . Is it by data on both
phones ? How will the cost be and what about the speed .Will it keep up
with a bad reception area?
Do I need to have 50 gig a month on each device I mean or is it much less than that?
Can the resolution of the camera phone be reduced as needeed?
Will Ret (author)  tytower2 years ago
I'm pretty sure only the phone with the IP Webcam app would be using data. It would probably cost a lot, and the speed wouldn't be great.
That's why I like using wifi.
The resolution can be reduced.
warhawk80802 years ago
I use IP Webcam on an old phone (with an ok camera) destined for the garbage with bad battery (soldered a USB wire directly to the battery teminals) mounted on an arm to monitor my 3D printer remotely in my home network
Isn't the USB voltage too high to connect directly to the battery terminals? When I had a dead battery I broke it and wired the electronics to an 18650 instead of the original lithium cell
Nah...it works just fine...but you need to have at a minimum a good 1A or higher feeding into it...the .8vdc shouldn't affect it at all...may make the battery icon read odd...but for my phone..worked goodv.
I have done the solder an 18650 as well when I wanted to ghetto a "backup" battery for a phone I used to run the APRSdroid app tied into a Baofeng UV-5R radio I had in my truck so it could report my location to the APRS servers...the reason I soldered directly to it was the charging port was destroyed by my kids and was an old phone destined for the trash, but I guess if you wanted a battery backup for power outages (because you have to manually restart phones once the power drops) it's a good way to go
ClareA52 years ago
Hi, great instructable....could I add more devices with the IP Webcam app?
Thanks!!!
You can get zoneminder and add as many cameras as you want to it...it will pull in the video and then monitor for movement from the feed to start recording. I believe they even have a Raspberry Pi port for it as well
http://petasek.ddns.net/random/ZM_ARM.png
Will Ret (author)  ClareA52 years ago
I'm very sorry, but I don't know if you can use more than one device, you'd have to try it for yourself.
Maybe another video player would support more than one. Or another app.
jejk2 years ago
Install Teamviewer on the phone and you will be able to access the camera + entirely control the device from any computer.
foureyes442 years ago
Cool! But nothing beats those actual cool-looking security cameras
Cell phones really do make the perfect spy cams. They have high resolution, a long battery life and a long range.
Will Ret (author)  DIY Hacks and How Tos2 years ago
You're right! Old cell phones are also a lot cheaper than buying a security system.
