book collections email follower instructable user
Picture of DIY Horn antenna for the Wi-Fi band (2.45 GHz)
In this tutorial we will construct a horn antenna for the Wi-Fi band at 2.45 GHz from a sheet of brass. All fabrication steps are explained and measurement results are provided in the last step. The results from a 3D electromagnetic simulation, such the Gain or the Radiation Pattern of this antenna are available here : http://kavea.free.fr
Step 1: Tools and materials
To build this antenna you will need:
  • 1 mm thick sheet of brass or copper
  • SMA connector
  • 1 mm diameter copper wire
  • soldering iron (min 50 W)
  • dremel or something similar to cut the sheet
  • drill
yshivu1 year ago
Nice explaination ....but how can we set the frequency of the horn antenna.
tytower2 years ago
Aditionally . If I use finer copper wire to construct the antenna would I not get a sharper bandwidth?
kavea (author)  tytower2 years ago
Yes, the diameter of the wire will change the BW but also the central frequency. However 1mm +/- 0.5mm will not affect a lot the result.
Which software do you use to simulate horn antenna?
dthurston12 years ago
Nicely done... so the next question .... how does one deal w/dual band wi-fi ...? Diplexer?
DT
kavea (author)  dthurston12 years ago
In practice a wifi antenna is made to be matched at both 2.45 GHz and 5 GHz (laptops etc). For home purposes it can be done with horn type antennas since it can provide very broadband response. In these two cases you dont need anything. However if you have two different antennas, one for 2.45 and other for 5 GHz band you will need a switch or a diplexer to isolate two antennas. Otherwise their impedances will be seen in parallel from the receiver.
Settles that ...
Any comments on mounting and direction ?
DT
Nothing special, as usually do not put it near metallic objects and respect the polarization (usually vertical so put the antenna like on first image, connector up or down)
tytower2 years ago
So what is the exact length of antenna you used? You say 3 cm but in your picture it looks longer by a few mm . length is critical to results so exactly how long was your test antenna? Additionally what is the basis of your measurement to position the antenna away from the sides? Can you give the source of these measurements please ?
The monopole is exactly 3 cm length, it seems to be longer because of the optical effect ;) Can you clarify your question about measurements ? You are talking about the physical dimensions or the S parameters measurements ?
tytower kavea2 years ago
I mean how do you calculate exactly where to position the antenna relative to the front back and sides?
Your welcome! The monopole should be placed 31 mm from the back and at the middle from the sides i.e. at 43 mm (86 / 2). This position has been optimized in the 3D FEM solver, but theoretically it's lambda/4 from the back . Any metal sheet will work if you respect the internal dimensions of the horn, an other point is the poor conductivity of some alloys which can lower the gain. And not all alloys are solderable. The best choice still copper, but more expensive than brass.
tytower tytower2 years ago
Oh and I meant to thank you for putting this up . I intended to make one but did not know where to start.
Also if I use alloy sheet will that work also?
