book collections email follower instructable user
Step 4: Source Code
Source code is available for free on GitHub: https://github.com/alojzjakob/Arduino-Color-Picker
You are more than welcome to improve the code, as the code provided is only the starting point, but works well.
This project uses these 2 specific libraries, so make sure you add these to your Arduino IDE:
#include <DFRobot_TCS34725.h>
#include <DFRobot_LCD.h>
#define ledPin 12 #define redpin 3 #define greenpin 5 #define bluepin 6
const int8_t button1Pin = 7; //1 const int8_t button2Pin = 8; //2 const int8_t button3Pin = 9; //3
int8_t button1State = 0; int8_t button2State = 0; int8_t button3State = 0;
#define ACTIVATED LOW
// for a common anode LED, connect the common pin to +5V // for common cathode, connect the common to ground // set to false if using a common cathode LED #define commonAnode true
// our RGB -> eye-recognized gamma color byte gammatable[256];
DFRobot_LCD lcd(16,2); DFRobot_TCS34725 tcs = DFRobot_TCS34725(0x50, TCS34725_GAIN_60X);
bool ledEnabled=false; int lightsMode=0;
// make some custom characters: byte light_on[8] = { 0b00100, 0b00100, 0b01110, 0b11111, 0b11111, 0b01110, 0b00000, 0b10101 };
byte light_off[8] = { 0b00100, 0b00100, 0b01110, 0b10001, 0b10001, 0b01110, 0b00000, 0b00000 };
byte rgb_on[8] = { 0b00000, 0b10101, 0b00000, 0b01110, 0b01110, 0b01110, 0b11111, 0b11111 };
byte rgb_off[8] = { 0b00000, 0b00000, 0b00000, 0b01110, 0b01010, 0b01010, 0b10001, 0b11111 };
void setup() {
lcd.init(); // create a new character lcd.customSymbol(0, light_on); lcd.customSymbol(1, light_off); lcd.customSymbol(2, rgb_on); lcd.customSymbol(3, rgb_off);
pinMode(ledPin, OUTPUT); digitalWrite(ledPin, LOW);
pinMode(button1Pin, INPUT); pinMode(button2Pin, INPUT); pinMode(button3Pin, INPUT); digitalWrite(button1Pin, HIGH); digitalWrite(button2Pin, HIGH); digitalWrite(button3Pin, HIGH); pinMode(redpin, OUTPUT); pinMode(greenpin, OUTPUT); pinMode(bluepin, OUTPUT);
analogWrite(redpin,0); analogWrite(greenpin,0); analogWrite(bluepin,0); // thanks PhilB for this gamma table! it helps convert RGB colors to what humans see for (int i=0; i<256; i++) { float x = i; x /= 255; x = pow(x, 2.5); x *= 255; if (commonAnode) { gammatable[i] = 255 - x; } else { gammatable[i] = x; } } }
void loop() {
button1State = digitalRead(button1Pin); button2State = digitalRead(button2Pin); button3State = digitalRead(button3Pin);
int btn=0; if(button1State==LOW){ btn=1; } if(button2State==LOW){ btn=2; } if(button3State==LOW){ btn=3; lightsMode++; if(lightsMode==4){ lightsMode=0; } }
uint16_t clear, red, green, blue; tcs.getRGBC(&red, &green, &blue, &clear); // Figure out some basic hex code for visualization uint32_t sum = clear; float r, g, b; r = red; r /= sum; g = green; g /= sum; b = blue; b /= sum; r *= 255; g *= 255; b *= 255; String redHex,greenHex,blueHex; redHex = String((int)r, HEX); greenHex = String((int)g, HEX); blueHex = String((int)b, HEX); lcd.setRGB(r,g,b); //Set lcd backlight RGB Value lcd.setCursor(0,0); // print values on lcd lcd.print("#"); lcd.print(redHex); lcd.print(greenHex); lcd.print(blueHex); lcd.print(" "); lcd.setCursor(0,1); lcd.print("rgb("); lcd.print((int)r); lcd.print(","); lcd.print((int)g); lcd.print(","); lcd.print((int)b); lcd.print(") "); if(lightsMode==0){ ledEnabled=false; lcd.setCursor(15,0); lcd.write((unsigned char)1);//light off lcd.setCursor(14,0); lcd.write((unsigned char)2);//rgb led on //Set the color of RGB led indicator analogWrite(redpin, round(gammatable[(int)r]/4)); analogWrite(greenpin, round(gammatable[(int)g]/4)); analogWrite(bluepin, round(gammatable[(int)b]/4)); } if(lightsMode==1){ ledEnabled=true; lcd.setCursor(15,0); lcd.write((unsigned char)0);//light on lcd.setCursor(14,0); lcd.write((unsigned char)2);//rgb led on //Set the color of RGB led indicator analogWrite(redpin, round(gammatable[(int)r]/4)); analogWrite(greenpin, round(gammatable[(int)g]/4)); analogWrite(bluepin, round(gammatable[(int)b]/4)); } if(lightsMode==2){ ledEnabled=true; lcd.setCursor(15,0); lcd.write((unsigned char)0);//light on lcd.setCursor(14,0); lcd.write((unsigned char)3);//rgb led off //Set the color of RGB led indicator analogWrite(redpin, 255); analogWrite(greenpin, 255); analogWrite(bluepin, 255); } if(lightsMode==3){ ledEnabled=false; lcd.setCursor(15,0); lcd.write((unsigned char)1);//light off lcd.setCursor(14,0); lcd.write((unsigned char)3);//rgb led off //Set the color of RGB led indicator analogWrite(redpin, 255); analogWrite(greenpin, 255); analogWrite(bluepin, 255); }
if(ledEnabled){ digitalWrite(ledPin, HIGH); }else{ digitalWrite(ledPin, LOW); } //delay(10); }
